Universe creation using flat files
Is i possible to create a uiniverse using flat files(excel,xml etc.).
Is it possible to create a single universe using tables from two different databases(oracle and sql).
Clarify me.
Many thanks in advance.
Rajaram.
rajaram1986 (BOB member since 2008-02-20)
I hope these are not interview questions… :?
Depends on the version.
Possible by DB linking, although it is not recommended performance wise.
Thanks Mak 1. In which versions(XI R2 and XI R3) it is possible to create Universe using flat files?
Not sure about the XML but you can create a universe from a xls spreadsheet in any version ( well at least from 6.x upwards)
dessa :madagascar: (BOB member since 2004-01-29)
Thanks Dessa,
We are currently working on BO XI R2.While creating a universe,we are specifying a data connection.For excel what data connection we have to establish.
Can you just guide me through the steps of using Excel sheets for creating a universe.
Many Thanks in Advance.
Rajaram.
Read this post
Courtesy of Digpen
