I have several (150) old reports that point to a universe. Now there is newer universe created from scratch and that universe has a different name. I want to point all my old reports to that newer universe with a different different name. Now I know I can Manually do this but that would be
Anyways I was hoping to find a automated solution and any other solution.
Below is one type of solution, Wait and see if others can chip in with more solutions.
Take a copy of the new universe.
Save the old universe as the new universe and export.
Point the reports at the ânewâ universe.
Save the copy of the new universe as itself and export.
Save the new universe as the old universe and export.
Point the reports at the old universe.
Dave Rathbunâs post about halfway through that thread makes sense and Reddy69 a couple of posts later atests to the fact that it worked.
However, the bit you quoted (or used) from the last post in that thread seems specific to fixing a problem steveayres had as per the second last post in that thread where his miagration to from 6,5 to XI didnât work to well.
AnywayâŚI think the original poster of this thread should go with Dave Rathbunâs solution
