Unhandled Exception Error Problem Reply
Dave wrote:
We started getting “Unhandled Exception Errors” on certain PC’s with certain universes starting with version 5.0.
We have had the same problem and I have worked with Technical Support on several occasions. They have had me delete keys from my registry, had me reinstall without my virus software (McAfee) enabled, on and on.
We have found if you delete the universe(s) from the PC and re-import them it has fixed the problem. We are on 5.0.01 and have experienced this problem since moving to the 5.x versions.
Hope this helps.
Susan Butts
