Unhandled Exception Code: c0000005
Dear all,
I am trying to modify a current report in order to add more columns. It is a very long story. The report is quite complicate one but with one DP. And the report applied outline with 4 breaks. The report works with simplified version(with fewer columns) but not with two other version.
Actually I got another report using the same structure, outline, dp, columns, etc… both simplified and complicated version work fine. But I really dun know why another one got different respond.
The report I got exception only when I click on the data box within the table, if I keep expand the outline or browse up and down. It work still fine. But later on I found even I move cursor over the table contain data. The exception will break out immidiately. That’s what I found most strange. :confused:
I tried near all the method stated. Only remaining re-install BO. Data extracted only around 1000 rows. Please help, I already over put effort on this damn report. Really frustrated now. Thanks a lot. :nonod:
BO 5.1.6
data db oracle 8.1
repository db oracle 9
1 processor x86 Family 15 Model 0 Stepping 0
Windows 2000 Workstation v5.1 build 2600 (Service Pack 2)
Physical Total/Avail: 253.424 Kb / 58.496 Kb
Temp directory C:\DOCUME~1\second27\LOCALS~1\Temp\ (12617208 Kb available)
‘Unknown’ video card
1024 x 768 in true color
Unhandled Exception
Code: c0000005
Description: EXCEPTION_ACCESS_VIOLATION
Call stack:
Module at 0x33ad0000: C:\Program Files\Business Objects\BusinessObjects 5.0\report50.dll v 5.1.6.22 [English (United States)]
address: 0x33c5f7be
address: 0x33b71d3d
address: 0x33b445bb
address: 0x33ad8287
address: 0x33ad86ae
address: 0x33c0691b
address: 0x33c05bd5
address: 0x33bbd98f
address: 0x33b4fdf1
Module at 0x73dd0000: C:\WINDOWS\system32\MFC42.DLL v 6.2.4131.0 [English (United States)]
address: 0x73dd1ead
address: 0x73dd1b9b
address: 0x73dd1b05
address: 0x73dd1a58
address: 0x73e6847d
Module at 0x77d40000: C:\WINDOWS\system32\USER32.dll v 5.1.2600.2622 [English (United States)]
address: 0x77d48734
address: 0x77d48816
address: 0x77d4b4c0
address: 0x77d4b50c
Module at 0x7c900000: C:\WINDOWS\system32\ntdll.dll v 5.1.2600.2180 [English (United States)]
address: 0x7c90eae3
address: 0x77d4ca67
address: 0x33c7813b
address: 0x33c78241
Module at 0x7c800000: C:\WINDOWS\system32\kernel32.dll v 5.1.2600.2180 [English (United States)]
address: 0x7c816d4f
lun (BOB member since 2005-10-03)
when you start having exception error with a report (nb : please avoid put crucial stuff like error msg only in subject), there are not a lot of solution, you have to recreate report because, I don’t know any solution to repaire corrupted report.
You can make it easy saving your report as ret file. Create another new report and re-create the query, then apply the ret file to this to retrieve style, tables and other stuff
regards
bernard
Welcome to B:bob:B!
Check out FAQ: Reporter this FAQ may help.
Dear Nick,
I already ready the FAQ repeatly, but I found my problem still can’t solve. As I found my case not very usual as moev cursor over the table also cause exception. What do you think? Thanks a lot for your reply.
Okay, I don’t think you mentioned that in your original post. There are lots of things you could try…opening as another user or on another machine or perhaps with a different version…all those things are worth checking out…and try the reinstall it doesn’t take long and if it does happen to solve your problem you won’t mind the inconvenience :wink:
Dear Nick,
I try reinstall the BO already. But still can’t fix. What can I do? :wah:
Actually I tried to send the report file (.rep) to other for openning it using BO 5.1.7 but not 5.1.6. However, no exception for that. If noly open .rep file work fine, can this prove anything?
And everytime I open the problem reports which contain history data, will this cause any problem?
