Unhandled Exception Code: c0000005
I have a problem while saving BO DESKI Report on to my local drive.
When I open the file and then try to save it, I get an Unhandled Exception:
Code: c0000005
Description : EXCEPTION_ACCESS_VIOLATION
followed by a BO crash.
If I copy the file to the other drive and open it in BO then save it I get no problem. I have checked the permissions for the other drive and looks the same permissions what i have on the other drive.
Please advise.
Many Thanks,
Madhu
Fulll Error Report.txt (20.0 KB)
madhu_pulluru (BOB member since 2009-03-11)
Hi Madhu,
You wrote :
Are you importing report from repository or from local machine?
Arjun (BOB member since 2008-07-28)
Check the FAQs!
It’s from Local Machine.
Many Thanks,
Madhu
