Working in BO XI3.1:
Can we unblock 6402 and 6403 ports by our self in our local machine, since I facing login issue with desginer and DI but WebI is working fine.
If yes, please let me know how? It will be a great help.
I’m getting the following error, when I login to Desginer or DI.
Cannot access the Repository (USR0013)
[repo_proxy 13] SessionFacade::openSessionLogon with user info has failed(Transport error: Communication failure.
(hr=#0x80042a01)
When I contacted SAP BO support team, they told me that may be due to some firewall installations/updates, these ports got blocked and need to unblock it as BO communicates through these ports. For that I contacted Admin team, but they are taking long time. So I thought to do it myself but don’t know how :(. Even I don’t know what block is meant exactly.
I presume that you mean opening the port, something that is needed to access Infoview in locked down work environments. It’s not something that you personally can do, but you should flag it to your manager that you cannot do what you have been asked without it and that the call will need chasing.
I dont agree to you on this… I think you can do it if you have admin rights on your machine.
But before that i would ask Manju to go back to SAP support and ask them clearly what do they mean by saying unblocking the port.
Because i had a problem installing BO XI3.1 and it took 8 wrong installation and uninstallations before success (this was due to my client who did not provide me the complete info and access to the server.
At that time i did all this.
But if you are telling Manju to take permission before doing any such major thing on a amchine which can affect the config or some other setting then i would say better ask the manager.
Else i dont find a reason why you cannot do it.
It’s going to depend on their setup Shiva - if it’s what I’ve faced then it’s about allowing certain ports on certain machines to pass traffic and if that involves corporate firewall configuration then there’s no way that Manju should be going near it and indeed probably hasn’t got the permissions to alter what is normally a sysadmin activity.
