Unable to see Conversion Add in In BO 5.1.6
I am using BO 5.1.6 and have added a conversion.rea file in my add ins to save a report as an excel.
However, when i login again, i do not see the tab “conversion” to save as excel.
Can someone help me out with it?
Tnkx!
bonovice_08 (BOB member since 2009-01-22)
Can you see the add-in in the menu Tools -> Add-ins?
And how did you add the add-in the first time?
I go to Tools -> Add ins -> Browse-> find the conversion.res(Its on my desktop) -> OK…
So now the conversion.rea is clicked to show that its added…
But i still donot see the conversion tab on the pane…
Can you inspect the code of the add-in to see where the problem might be? It’s hard to debug it from a distance.
[Moderator Note: Moving to SDK forum]
