unable to create Datastore Sybase ASE connection error
Trying to create a data store connected to Sybase ASE server. Tried different combination of db server name like server name, server name + port number, IP, & IP + port number. It giving me same error all the time…
Tested connection is ODBC it work fine but same config from same server it gives me following error…
Can you help us my your valuable comment on this issue…
WARNING: Cannot establish database connection.
‘Sybase connection error: <Sybase CS Library message number
<101188867> Serevity <5>: Message Text is ct_connect():
directory service layer: internal directory control layer error:
Requested server name not found>’ <BODI-1111341)
Do you want to save this datastore anyway?
RajPatel (BOB member since 2005-05-19)
