I created RT job in DS 3.1 .I created web service for this job and generated WSDL from admin console .When i am calling this WSDL file in SSIS ,its not showing any methods .Where as i can external webservice in SSIS.
i tried to call my DS webservice in onother DS job,its working fine.
I think the problem is SSIS can’t pick DS generated WSDL file.
Is any body faced this problem?please help me on this…it’s urgent
Please find DS generated WSDL file below.
<?xml version="1.0" encoding="UTF-8" ?>
- Web Services published by BusinessObjects Data Services Version 12.1.1.2, using Apache Axis 1.1
- <xsd:schema elementFormDefault=“qualified” targetNamespace=“http://businessobjects.com/service/RT_DIRLKP_WS/input” xmlns=“http://businessobjects.com/service/RT_DIRLKP_WS/input” xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>
xsd:annotation
<xsd:documentation xml:lang=“en”>XML Schema generated by Data Integrator</xsd:documentation>
</xsd:annotation> - <xsd:simpleType name=“DIType-varchar-10”>
- <xsd:restriction base=“xsd:string”>
<xsd:maxLength value=“10” />
</xsd:restriction>
</xsd:simpleType>
- <xsd:element name=“DIRECTORY_IN”>
- xsd:complexType
xsd:sequence
<xsd:element ref=“LOOKUP_NAME” />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name=“LOOKUP_NAME” type=“DIType-varchar-10” />
</xsd:schema> - <xsd:schema elementFormDefault=“qualified” targetNamespace=“http://businessobjects.com/service/RT_DIRLKP_WS/output” xmlns=“http://businessobjects.com/service/RT_DIRLKP_WS/output” xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>
xsd:annotation
</xsd:restriction>
</xsd:simpleType> - <xsd:element name=“DIRECTORY_OUT”>
- xsd:complexType
xsd:sequence
<xsd:element ref=“LOOKUP_NUMBER” />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name=“LOOKUP_NUMBER” type=“xsd:integer” />
</xsd:schema> - <xsd:schema targetNamespace=“http://www.businessobjects.com/DataServices/ServerX.xsd” xmlns:localtypes=“http://www.businessobjects.com/DataServices/ServerX.xsd” xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>
- <xsd:element name=“BatchJobResponse”>
- xsd:complexType
xsd:sequence
<xsd:element name=“pid” type=“xsd:int” />
<xsd:element name=“cid” type=“xsd:int” />
<xsd:element name=“rid” type=“xsd:int” />
<xsd:element name=“repoName” type=“xsd:string” />
<xsd:element minOccurs=“0” name=“errorMessage” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Ping_Input”>
xsd:complexType
<xsd:sequence />
</xsd:complexType>
</xsd:element> - <xsd:element name=“pingVersion”>
- xsd:complexType
xsd:sequence
<xsd:element name=“version” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“LogonRequest”>
- xsd:complexType
xsd:sequence
<xsd:element name=“username” type=“xsd:string” />
<xsd:element name=“password” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“session”>
- xsd:complexType
xsd:sequence
<xsd:element name=“SessionID” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Logout_Input”>
xsd:complexType
<xsd:sequence />
</xsd:complexType>
</xsd:element> - <xsd:element name=“responseStatus”>
- xsd:complexType
xsd:sequence
<xsd:element name=“status” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:simpleType name=“TracingTypeType”>
<xsd:enumeration value=“job_trace_all” />
<xsd:enumeration value=“job_trace_row” />
<xsd:enumeration value=“job_trace_session” />
<xsd:enumeration value=“job_trace_workflow” />
<xsd:enumeration value=“job_trace_dataflow” />
<xsd:enumeration value=“job_trace_transform” />
<xsd:enumeration value=“job_trace_usertransform” />
<xsd:enumeration value=“job_trace_userfunction” />
<xsd:enumeration value=“job_trace_abapquery” />
<xsd:enumeration value=“job_trace_sqlfunctions” />
<xsd:enumeration value=“job_trace_sqlreaders” />
<xsd:enumeration value=“job_trace_sqlloaders” />
<xsd:enumeration value=“job_trace_optimized_dataflow” />
<xsd:enumeration value=“job_trace_table” />
<xsd:enumeration value=“job_trace_script” />
<xsd:enumeration value=“job_trace_ascomm” />
<xsd:enumeration value=“job_trace_rfc_function” />
<xsd:enumeration value=“job_trace_table_reader” />
<xsd:enumeration value=“job_trace_idoc_file” />
<xsd:enumeration value=“job_trace_adapter” />
<xsd:enumeration value=“job_trace_communication” />
<xsd:enumeration value=“job_trace_parallel_execution” />
<xsd:enumeration value=“job_trace_audit” />
</xsd:restriction>
</xsd:simpleType> - <xsd:complexType name=“job_param_type”>
xsd:sequence
<xsd:element minOccurs=“0” name=“job_system_profile” type=“xsd:string” />
<xsd:element maxOccurs=“1” minOccurs=“0” name=“sampling_rate” type=“xsd:int” />
<xsd:element maxOccurs=“1” minOccurs=“0” name=“auditing” type=“xsd:boolean” />
<xsd:element maxOccurs=“1” minOccurs=“0” name=“recovery” type=“xsd:boolean” />
<xsd:element maxOccurs=“1” minOccurs=“0” name=“job_server” type=“xsd:string” />
<xsd:element maxOccurs=“unbounded” minOccurs=“0” name=“trace” type=“localtypes:TracingTypeType” /> - <xsd:element maxOccurs=“1” minOccurs=“0” name=“distribution_level”>
- xsd:simpleType
<xsd:enumeration value=“Job” />
<xsd:enumeration value=“Data flow” />
<xsd:enumeration value=“Sub data flow” />
</xsd:restriction>
</xsd:simpleType>
</xsd:element> - <xsd:element maxOccurs=“1” minOccurs=“0” name=“substitutionParameters”>
- xsd:complexType
- xsd:sequence
- <xsd:element maxOccurs=“unbounded” minOccurs=“1” name=“parameter”>
- xsd:complexType
- xsd:simpleContent
- <xsd:extension base=“xsd:string”>
<xsd:attribute name=“name” type=“xsd:string” />
</xsd:extension>
</xsd:simpleContent>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType> - <xsd:element name=“CCRPOC1_JOB_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“aggregateAmounts” type=“xsd:string” /> - <xsd:element minOccurs=“0” name=“Category” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Custom1” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Custom2” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“DataEntryPeriod” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“erasePackageAmounts” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“importZeroBalances” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“JobRunId” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Password” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“publishPackage” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“ReportingUnit” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“runControls” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“runPackageRules” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“User” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“JOB_LOAD_R3_GL_Test_Table_Compare_GlobalVariables”>
- xsd:complexType
xsd:sequence
- <xsd:element minOccurs=“0” name=“CountMappingErrorRecords” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“DataEntry_Period_Month” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“DataEntry_Period_Year” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Error_Message_Out” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“MappingErrorTable” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Parameter_Validation” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“R3_FTP_Filename” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“ReportingUnit_Modified” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“WORD_COUNT” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Job_Load_Exchange_Rates_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“Category” type=“xsd:string” /> - <xsd:element minOccurs=“0” name=“Custom1” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“FiscalPeriodMonth” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“FiscalPeriodYear” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“FiscalYearPeriod” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“RateType” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“SourceFileName” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“JOB_LOAD_R3_GL2_GlobalVariables”>
- xsd:complexType
xsd:sequence
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Job_Load_WUCS1_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“Account” type=“xsd:string” /> - <xsd:element minOccurs=“0” name=“aggregateAmounts” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“JobRunID” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“PeriodMonth” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“PeriodYear” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Job_Load_BW_GPS_SCHEDULED_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“aggregateAmounts” type=“xsd:string” /> - <xsd:element minOccurs=“0” name=“ArchiveDirectory” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“CompanyCode” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“CompanyCodeCount” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Counter” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“DefaultFlowValue” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Error_Message_Footer” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Error_Message_Header” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“FileName” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“FIMMappingErrorCount” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Function_ErrorMessage” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Function_Validation” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“InboundDirectory” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“LOG” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“NewJobGlobalVariable0” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“NewJobGlobalVariable2” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“ProcessingDirectory” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“RoundingAccount” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“RoundingFlow” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“RoundingProfitCenter” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Version” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“VersionPull” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Job_Load_BW_GPS_GlobalVariables”>
- xsd:complexType
xsd:sequence
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“Job_BOFC_TO_BW_Package_GlobalVariables”>
- xsd:complexType
xsd:sequence
- <xsd:element minOccurs=“0” name=“CHECK_STATUS” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Currency” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“LOGID” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“LOOP_STATUS” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“PROCESS_CHAIN_NAME” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Scope” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“SOURCE_TABLE” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“SQL_TEXT” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Variant” type=“xsd:string” />
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“JOB_TEST_FIM_DS_HA_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“counter” type=“xsd:string” /> -
</xsd:sequence>
</xsd:complexType>
</xsd:element> - <xsd:element name=“JOB_LOAD_FLATFILE_ACTUALS_GlobalVariables”>
- xsd:complexType
xsd:sequence
<xsd:element minOccurs=“0” name=“ActiveJobRunId” type=“xsd:string” /> - <xsd:element minOccurs=“0” name=“aggregateAmounts” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Archive_filename” type=“xsd:string” />
- <xsd:element minOccurs=“0” name=“Archive_flatfile” type=“xsd:string” />
Sandy
sandyrao (BOB member since 2007-04-26)
