Hi Experts,
I have come across an issue as I have not worked a ton on File Formats, Suggestions / recommendations are appreciated.
Scenario:
We have a Task, where we need to export all the list of Materials and its descriptions into a .txt file, where DS can Consume and Send it to all Apps.
Note: we have Material Numbers with all the characters (@#!~*") (You name it from the library). We are using substring to export with a logic and below is the description.
Format Setup:
We are exporting a file with simple select and load with Pipe ‘|’ as delimiter.
Issues:
-We have data with PIPES (|)
-We have data with Double quotes (")
Example:
Raw Material - ABC"|123
Material in File - “ABC”“|123”
Material when file opened in excel - ABC"|123
Material BODS File Format shows after importing - ABC|123
File format setup in BODS is
-Delimited
-| is the delimiter
-TEXT is set to " so it can identify delimiters within data.
We are missing double quotes within the data
even after all this.
We can try any other character but Material has it anyways so its always an issue.
KP
Randy_KP (BOB member since 2012-10-23)
