Two objects in WHERE condition at Report level variable?
I want to create a report level variable based on the values of two other objects.
The formula for Variable I am trying to create looks like this.
=<Object1> Where (<Object2> = <Object3)
But BO gives a syntax error for . I think it expects a constant value as second operand.
Is there any work around or technique to achieve this?
-Manish
mkumar (BOB member since 2002-08-26)
Please, take a look at the FAQ Reporter
Hmmm, that explains it well.
Here is my problem. I hope somebody could help me with the solution.
I want to show Current Day and Previous Day’s data in two separate columns in report. The data is stored in a single column in database.
The current date is entered by user via a prompt.
If the user selects 01/04/2004, the report should look like this.
Date               Current Data              Previous Data
01/04/2004          10                                 6
01/03/2004           6                                  8
01/02/2004           8                                  7
If the user selects 01\03\2004, the report should look like this.
01/03/2004           6                                  8
01/02/2004           8                                  7
01/01/2004           7                                 10
The database looks like this.
Date                 Data Value
01/04/2004           10
01/03/2004           6
01/02/2004           8
01/01/2004           7
31/12/2003           10
Any ideas how this can be achieved with a single data provider. Using two DPs will definitely reduce the performance.
Basic sketch of how I would approach this:
You’ll have to create two flags, one called (for example) Current Day Flag and another for Previous Day Flag. Those will be based on a comparison between the data from your data provider and the prompt… if the day = prompt date then 1 for current, if relative_date(day, +1) = prompt then previous day flag = 1. Then you can use the Where clause with the two flags.
Using Plain SQL we can do something like this to get the desired result… See if you can make it for your use…
SELECT
	DATEID,
	DATEVALUE,
	(SELECT DATEVALUE FROM TABLE1 A WHERE A.DATEID + 1 = TABLE1.DATEID)
FROM
	TABLE1
WHERE
	DATEID <= TO_DATE('03-JAN-2004')
AND	DATEID >= TO_DATE('03-JAN-2004') - 2
Note:
Plz check the exact syntax.
Sri
Sridharan :india: (BOB member since 2002-11-08)
