Hello,
I am about to start work on a project using BO 5.0 and Oracle. I currently have BO 4.1 installed on my workstation in a SYBASE System 11 environment. I am the BO supervisor/administator and support some production applications which have not been upgraded to BO 5.0 yet so I cannot upgrade my version of BO to v 5.0. Is it possible to install BO V 5.0 (in separate directory) without it affecting my 4.1 version? Unfortunately, I do not have a second hard drive.
It will ask u 2 preserve earlier version, and yes, it works ok
Good luck,
Brent
Hello,
Yes you can have 4.1.x and 5.0.2 installed on the workstation without problems. I have had both on multiple workstations for over 8 months. Until my user base is converted to 5.0.2 next month I will continue to have both versions on my system(s).
The standard install process allows you to make this selection.
Mike McErlain
McErlain Consulting @ Cisco Systems
At 12:14 PM 4/4/2000 -0400, you wrote:
Hello,
Hi Judith
Yes you can intall B.O 5.0 and B.O 4.x on the same machine. While installing B.O 5.0 it will ask you an option like. “Do you want to keep/overwrite the existing 4.x installation”. Select keep an existing installation and select a different directtory for installation. Hope this information helps
Bye
Raheel
