Hello,
I am trying to keep the details of a report together when using Multiple Columns. I will have the header and partial details in column 2 and the rest of the detail will continue into column 3. Is there a way to keep all detail together in columns in the same way it Keeps Together on the page?
thanks
From your description, I cannot quite tell if you have grouping set up, or multiple Detail sections (Details a, Details b, Details c, etc.).
If you have multiple Detail sections in multiple columns, open Section Expert, click on the main Details section (the one without an a, b, c, etc.), and then select “Keep Together”.
If it is different from this scenario, give some more information and we may be able to get this fixed for you.
I would like to build a report where used 2 detail sections and like to appear in a report as below: Is it possibe? if yes, please advice how can be achieved.
Detail a
Detail a
Detail a
Detail a
Detail a
Detail a
Detail a
