Hi Everyone,
I have downloaded the files from “How to set preferences for all users at once in BO XI R2” under samples. Now, I’m not sure how I should deploy and configure. We are on XI3.1 and use Infoview (Java) to run Webi and Crystal reports. We are wanting all users to bypass the first Infoview screen and go directly to the Document List screen. Also we have configured for SSO AD.
Login to InfoView, go to Preferences and under ‘InfoView Start Page:’ section, select ‘Folder’ and then select the root folder as your start up page. This will allow you to by pass the home screen.
Farhan,
Thanks for the reply. I should have made it more clear in my original post that we want all users to bypass the first screen without having to manually change for each user. The software I downloaded from SAP is suppose to be able to point all users or a group of users to a preference. I’m just not sure how I am to deploy and configure to get this to work.
I need to do the same thing. the following is all I found to do it for all users, other then using the script. The script would likely work, problem is, my users have different prefs, so using the script would overwrite those.
In InfoViewApp.war\jsp\listing\home.jsp or tomcat\webapps\InfoViewApp\jsp\listing\home.jsp
Remember, if you modify the jsp in the webapps folder it may be redeployed be the war back to default. Also, you may need to clear the tomcat\work\ folder to see the changes.
To answer the question regarding the pushing of preferences in XI 3.1, it is my recommendation to use the PrefsCopyUtil utility described in this post on the 4th page. It is the easiest way of pushing preferences to a group of users.
