I have a BODS job that loads data from a csv file into an integer column in a DB2 table. Usually the csv data is reliably clean, so my BODS job does not pre-validate the csv file data. Instead, in order to be notified in the unlikely case that the input data is bad I just put a try/catch around the workflow to send an email if any error occurs loading the data. I tried testing that today by purposely giving it bad data, and was surprised to find that it isn’t catching the data conversion error. Does anybody know why that could happen? Are there some errors that aren’t catchable? In my catch declaration every exception type is checked. The data conversion error looks like this:
(14.0) 02-03-14 16:35:49 (E) (7868:3652) RUN-050802: |Data flow DRT_DF_LoadInputData|Reader DRTLAB_INPUT_FMT1
Cannot convert data <9-999-999> into type . Context: Column .
That doesn’t seem to be the case, because the BODS job doesn’t get past the attempt to load the .csv file. That data conversion error is the only thing in the BODS error log. The BODS trace log shows that dataflow starts, but doesn’t show the dataflow ending. In the Data Services Management Console the job status is the big red X. That means the job failed right? I see the End time in the console is blank, even though this job failed many hours ago.
They are both {no limit}. Other relevant looking settings under Error Handling are: log data conversion warnings Yes, log row format warnings Yes, capture data conversion errors Yes, capture row format errors Yes.
The Try/Catch block is actually capturing the exception, its just not one of the exceptions to be handled. This is why when a job which normally crashes on a file format error, returns a 0 return code even though it produced an error.
This wreaks havoc on our job streams built in our 3rd party scheduler. The next job in the job stream gets fed a 0 return code from this job, and continues merrily along with the next set of jobs.
Thanks for you reply…can you please give a scenario or example to make it more clear…or if you have any PDF/document please send me on d.parijatam@gmail.com
