Trim in custom SQL
I want to trim all leading and trailing spaces for every dimension in a query, using custom SQL on MS-SQL DB, what i have tried thus far is generating errors on validate just for one dimension? any suggestions
Tony_C_Florida (BOB member since 2014-09-28)
Don’t know MS-SQL DB, so maybe a stupid question but; are you sure your Dimension is not a string?
Stef102 :belgium: (BOB member since 2014-08-05)
Can you please post what you have tried so far and it did not work?
I’d recommend doing it at the ETL stage rather than within the universe.
Are all objcets that need trimming varchar/char fields or are numbers and dates in there as strings with leading/trailing spaces?
fields seem to be both Text / char and number. Some appear empty but have char in them. Need to trim.
Have tried LTRIM(RTRIM(
Give me a error 'The data type of a column in the query is not valid" IES 10811)
Seems MS SQL does not have a general trim. Yes it would be better to do in ETL or Universe but not an option for this at this time. Would be a major project I need answers this week.
Start creating views
Use a combination of ltrim(rtrim(colname)) and casting/converting to get the table you want:
create view v_table1 AS
select
cast(ltrim(rtrim(col1)) as int) col1_int,
cast(ltrim(rtrim(col2)) as varchar(20)) col2_vc20,
cast(ltrim(rtrim(col10)) as date) col10_date
from
table1 WITH (NOLOCK)
