Trasport my crystal report from DEV to Quality. How to do it
I have developed some crystal reports in Development system. how i have to transport them to the Quality system… Do i have to use CMC? how it will appear in quality. I am new to BO. Can anybody help me with this?
reachpathuri (BOB member since 2017-09-13)
Which version of BO are you using?
If it’s 3.1 or older, then you would use the Import Wizard. If it’s 4.0 or newer, you would have to have access to Promotion Management in the CMC.
-Dell
Hello hilfy
Thank you for the reply. I am using BO 4.2 version. Need to use Promotion management i believe.
Pathuri
