I have a need to generate labels names out of rows.
I have two columns in my table.
row1 - ‘redOverride’, ‘orange’
row2 - ‘blueOverride’,‘green’
row3 - ‘yellowOverride’,‘amber’
rown - 'lastValue,‘none’
I will use these labels in my master report.
In oracle, I can use pivot by means of following.
select max(case when Attribute=‘redOverride’ then value else ‘red’ end) Label1,
max(case when Attribute=‘blueOverride’ then value else ‘blue’ end) and so on
from TableLabelValues
My universe will have only two objects Attribute and value
I will be using label1, label2 and so on in my master report. If there are no label overrides then I will use my default label, ie, red, blue, yellow etc.
Any ideas will be greatly appreciated.
paddy_iyer (BOB member since 2005-09-22)
