Not sure if this is possible? … but
Does anyone know of a way to make table fills transparent?
I.e - just display the text in the table with the page background visible through the table?
cheers
Reporter Bloke (BOB member since 2004-05-20)
cheers
Just remove the fill. Select the cells of the table, select Format + Cell, select the “Appearance” tab and set the “Fill” setting to None. I believe that will do it. 8)
Hmm i thought that as well -
seems to be a bug in the version im testing with
thx
Hi Bloke
What u thought is right. It is a bug and not yet fixed in the near versions.
bobjkb (BOB member since 2004-03-19)
Works fine in 5.1.7… what version are you (Reporter Bloke) using?
Works fine in 5.1.7 and 6.1a…
Try this:
=>Format
=>Cell
=>Shading
=>Fill
=>None
Gregc M. (BOB member since 2003-11-03)
