transparent Gif for table background is not transparent
I’m trying to style a report and use a gif with transparency as the table’s background. Selecting the gif file works just fine, as I do see the image as the table’s BG, but it’s not transparent. The parts that should be, are white.
This leads me to the conclusion that BOXI does not support image transparency, though I hope I’m wrong.
Do any of you have experience with this issue? can you offer any help/ advice?
-Ethan
ethan1701 :israel: (BOB member since 2004-05-05)
