In aid of making funky BI Widgets for use with R3, does anyone know if its possible to make a Xcelcius canvas transparent, can
t find an option anywhere.
Andy
ABILtd (BOB member since 2006-02-08)
Andy
Bumping this to the top. I would also like to see how this is done.
Anverion (BOB member since 2007-03-15)
Me too!
Cedrick
cedrickb (BOB member since 2005-08-19)
Still no one ? Documentation says background (=canvas) is transparent by default, but it seems it’s not.
I opened a BO case to ask a few questions about widgets. If I have an answer about this issue I’ll tell you then.
Thank you
titlola (BOB member since 2007-01-10)
Are you trying to see this transparency before you use the dashboard for creating your widgets ? Or are you having transparency issues once you run your widgets ?
When you load an Xcelsius generated SWF into BI Widgest, the existing white canvas background is removed by BI Widgets. The result is that the whitespace in your Xcelsius visualization will remain transparent.
I have not yet tested this in XIR3 myself, but remember this working fine when I was using XIR2 earlier.
Naresh Ganatra (BOB member since 2004-04-09)
In my case, I have a blank background when the widget is on the desktop. BI Widgets does not seem to remove the blank background as it is written in the user manual.
