BusinessObjects Board
Track Usage without Auditor?
I understand that Auditing is required to capture the statistics/metrics of system, users, and documents. But is there anyway where I can get an answer for the “When was the last time user login to Infoview?”?
selvaips (BOB member since 2005-05-03)
Here is a simple way that you can see the last logon time (and last failed logon time) of a user by querying the Business Objects Repository
note: You will need an Administrator type account
Log into Query Builder
the address for query builder is
http://[SERVERNAME]:[PORT]/AdminTools
enter the following query
SELECT
SI_NAME
,SI_LASTLOGONTIME
,SI_LAST_FAILED_LOGON_TIME
FROM CI_SYSTEMOBJECTS
WHERE
SI_NAME = ‘[USERNAME]’
replace [USERNAME] with the Business Objects account name you are interested in
click Submit Query
buzz :australia: (BOB member since 2005-08-12)
Great…!! This is what I needed. Many thanks…!!
