I would like to print a Page N/M on the footer of my report.
The N and the M need to be reseted for each group.
For the N, i can write a formula, but for the M, i have no idea how to do it.
TotalPagecount will not work, it is not reseted and doesn’t print the total page number of each group.
I would try adding the PageNofM formula to your existing report.
I would then build a new report with the same grouping structure as the existing report (except the most inner group) and add the existing report as a sub-report, suppressing all sections of the new report except detail.
I think this will then reset the page counts because each group on the new report will call a separate instance of the sub-report.
