system
July 15, 2011, 10:25am
1
what specifies the top of page in my report?
my requirement is having
top of page, sections and data. I dont know waht to do first?
one of the top of page column is listed in section also.
how can i do this?
is my requirement clear to do?
rbogireddy (BOB member since 2011-06-13)
system
July 15, 2011, 10:35am
2
you may have to explain it clearly or post an image/excel which describes your requirement
jprasanthram (BOB member since 2010-12-10)
system
July 17, 2011, 3:25pm
3
Refer to the map after you first see if ur requirement means report header or top of report.
inokhands (BOB member since 2011-06-03)
system
July 18, 2011, 3:38am
4
It depends entirly on your requirement.
When you say top of page, you can either have report header or you can have section header as your top of page, as said before if you give the screenshot or explain it bit more, that might help us in understanding the requirement…
aniketp (BOB member since 2007-10-05)
