Top 9 and 'others' in Infoview
I want to calculate and show in CHART, Top 9 brands and rest should come under ‘Others’ which is not actually at the db level. So, I need to acheive this @ the universe/report level.
ex, in bar graph
Y-Axis->Revenue
X-Axis->b1,b2 b3…b9,Others
Is there any way we can acheive this in Infoview or in universe.?
Please help me.
regards,
Prasath.
nprasath2007 (BOB member since 2010-06-07)
hi!
here’s a solution for webi https://bobj-board.org/t/156066
search is your friend! :wink:
R.A. :philippines: (BOB member since 2008-10-28)
I tried using the if(rank())>4;“Others”;[Brand]) , it works in tha table but it doesn’t work in the bar chart.
Any other effective solutions please.
regards,
Prasath.
wow! stubborn little child!
anyways… you did not search the forum that well… here’s the answer!
=If(IsError(If(Rank(<measure>;<dimension>) < 3;<dimension>;"Other") In(<dimension>));"OTHER";If(Rank(<measure>;<dimension>) < 3;<dimension>;"Other") In(<dimension>))
you can find the answer here: https://bobj-board.org/t/139201
READ THE TOPIC THOROUGHLY.
Thanks for your reply.
But, with that formula…
=If(IsError(If(Rank(;) < 3;;“Other”) In());“OTHER”;If(Rank(;) < 3;;“Other”) In())
I tried it, so the first part in the IF condition always gives you the ‘Multivalue Error#’, So, the IsError() function doesn’t fail.So, the ‘OTHER’ value is geting displayed. with just ONE BAR
Bus what about the rest of the vaules in the dimension which is less than the ranking value…?
I want to show…b1,b2…b9,Other in BAR CHART.
Even I tried, =If(If(Rank([Sales revenue];[City])>4;“Others”;[City])=[City];[Sales revenue];Max(If(If(Rank([Sales revenue];[City])>4;“Others”;[City])=[City];[Sales revenue];RunningSum([Sales revenue]))) ForAll ([City]))
The above code works and shows you the ‘OTHER’ total but we will see the Xaxis with
b1,b1,b3,b4,…b9,b10.
the condition here is where rank>4 is ‘OTHERS’. So, for b4 to b10 it will show you the ‘Others’ Total in the y axis ‘bar’ but the X-axis still displays b4…b10 :frowning:
any suggesions please…?
Also, I have gone thro’ the TOPIC THROUGHLY…but no use.
regards,
P
hhhmmm… it’s working fine in my testing… just to check, did you make your rank forumula a detail? if not, force it to be a detail not a dimension.
:roll_eyes:
Hi R.A,
yeah I am tried making it ‘DETAIL’, but still its showing just the ‘OTHER’ in Xaxis and the correspoing value in the yaxis.
Any other suggesions…?
P
Guys…?
Help me out pleazzzzzzzzzzzz…
any other suggesions…?
regards,
P
Hi I have tried this using Island Resorts Marketing.
Ranking based service and revenue. Created a variable called TOP6 - =If([Ranking]>5;“others”;[Service])In([Service])
Then created Pie chart using : TOP6, Revenue.
Kon Bobj :uk: (BOB member since 2005-06-06)
Still I am geting the CONTEXT# or MULTIVALUE# error.
If it is Top6,Revenue and Service then we will see something in the PIE/Bar chart. but the axis shows like Ser1/Others,Serv2/Serv2…etc.
Any other pls…?
Prasath.
Guys common any creative ideas…?
