Can you guys suggest the steps or point me to right documentation for upgrading tomcat 5x of BOXI 3.1 to Tomcat 6x?
Benking
benking1974 (BOB member since 2010-08-24)
Benking
I do not believe Tomcat 6 is supported for BOXI 3.1 (it is for BOXI 4).
kevlray (BOB member since 2010-06-23)
Tomcat 6 (6.0.18 to be exact) is supported in BO XI 3.1 SP3.
Hi guys,it can be support 6.0.18 from SAP official feedback. Now we have upgrading BO XI from sp3 to sp4 successfully, and Tomcat from 5.5 to 6.0.18 64bit. Hope my answer is what you need.
Jenson (BOB member since 2011-09-21)
Just a heads up, we’ve noticed that while 6.0.18 is supported in SP3, that some of our Xcelsius dashboards that support QAAWS are not functional. When we checked the supported platforms doc for SP3, there is a footnote that clearly states that 6.0.18 is not supported when Query as a Web Services performance enhancement is activated.
rbarrera (BOB member since 2008-09-03)
Do you know what it is? How can I know if it’s been activated or not? Do I need to ask dashboard developers whether they used it or not?
Thank you.
Did you ever get an answer or link to documentation explaining what is involved to upgrade TomCAT for BoXI?
I just upgraded BoXI to SP5 (& it looks to be ok so far), but I also need to upgrade the default Tomcat 5.5.20 to something newer (probably a version 6xxx) to accomodate client’s upgraded Internet Explorer.
I would be interested in any feedback you may have received.
Carol
carol.gottlieb (BOB member since 2008-10-01)
I’ve always found Tomcat installs to be failry painless - typically I stop Tomcat, rename that install folder, and then run the new installer. Once you have Tomcat, just deploy all the WAR files and try it out.
Lots of posts out here about doing minor upgrades, should follow those, unless you’re into updating supoorting software, too (java…?).
Good luck!
B
bdouglas (BOB member since 2002-08-29)
Thanks. I got some ‘steps’ from SAP techie also. It doesn’t look too terribly difficult. I was just concerned about making sure that my BoXI & SIA would use the new version. But it sounds pretty simple.
Here are steps I got in case anyone might be interested:
Following are the steps required to install Tomcat 6 :
Now other ‘apps’ may be a different questions. JAVA probably could also be updated depending on the versioning within BoXI. But that is another discussion that I’m not ready to approach.
Just one step at a time…
Carol
It’s seems to be linked with the Xcelsius Cache Server and Xcelsius Processing Server. have a look to SAP Notes #1627336
bernard timbal (BOB member since 2003-05-26)
Thanks but it’s too late, my friend It’s been more than 2 years since I left the client where I needed it.
But it’s never too late to learn something new, so thank you
Facing this same question, I searched first on BOB, then on BO-SAP tech support. Found the answer on it ( ) then tried to share it with you updating the two posts in BOB
