To prompt while refresh and not to prompt for DAS
Would appreciate a solution to the following.
What expression or logic to use for creating a BO report where : 1> I will be prompted for say, a date, when I refresh it 2> and this same report when I submit to DAS, a subquery will compute the date without being prompted.
I am using Oracle 7.3.4 as backend and BO 4.1.5.
Thanks much in advance.
Unni
E-mail : K.Unnikrishnan.Nair@ercgroup.com
Unni,
What do you mean by Sub-query? Can it be represented by BO?
I think what you need is, create a query with a prompt which will throw prompt screen while refreshing the report from BusinessObjects and create a script and attach it with the DAS job which will set the date value for the prompt variable.
  • Vasan
What you could do is to put the query for the date into the report itself, and use that result/date in your report as a variable. Simon
Do you have a Script that does this. IF so can you please mail it.
Pavan
im really sorry pavan. i didn’t check list serv for many days.
it’s very simple:
Application.Variables(“Enter Start
Date:”) = “24-Jan-1999”
Try the above line to populate prompt, whicch has text “Enter Start
Date:”
if u r using BO4.x, parameters will be passed as string only. in bo5 u can also set the type of the parameter.
let me know if u need detailed help
vasan
