- What is meant by cube?
- How to slove the Isolated Join?
stalint (BOB member since 2004-12-14)
Stalint…
Welcome B B
cube
A subset of data, usually constructed from a data warehouse, organized and summarized into a multidimensional structure defined by a set of dimensions and measures. A cubeÂ’s data is stored in one or more partitions.
This is a defintion i got from a book
Did you try a search in BOB…
This would give you answer for 2nd Question.
Manu
mada (BOB member since 2004-11-25)
hai thanks for rply…
You set cube is a subset of data… like scope analysis is also same then
Cube in the generic sense is indeed used to describe the multi-dimensional data structures use in an OLAP environment.
In Business Objects specifically, the term microcube refers to the two dimensional row / column results of a data provider. The results of a data provider are then available to be used in the report itself.
Does that help?
Dwayne Hoffpauir (BOB member since 2002-09-19)
Moving this topic out of the Supervisor forum …
