Timezone conversion
I want to convert the datetime field from UTC to local timezone. Is this possible?
bohelp22 (BOB member since 2011-05-14)
Yes, in fact there is a special function for that. Check this link. https://archive.sap.com/discussions/thread/2047372
kevlray :us: (BOB member since 2010-06-23)
Thanks but that doesn’t work. I need a sample formula to convert UTC to Local EST.
Were you able to fix this? I need help with same thing. I need a sample formula to convert UTC to Local EST.
kohli664270 (BOB member since 2019-03-08)
