=NoFilter(Max(([Amount of All Transactions]/[Agreement Balance ( D )]) In([Servicing Account Nbr];[ProductGroup])))
Checked syntax, was correct so I validated it and then received a timeout error. At first I figured it was a local issue and I didn’t relate the timeout with what I was really doing so I tried a couple of more times. Apparently it dropped the webi processing server for a couple of minutes each time.
I didn’t know it was even possible to get such an outcome with a report-level variable. The conflicting functions seem to be the NoFilter() and In() or Max() and In(). They run separately, but combined are one heck of a recipe for destruction…
Has anyone ever encountered anything like this, dropping the whole damn server with just a report-level variable, did I create an infinite loop or what?
So, can you get the logic to work if you break it up with named variables?
It may have nopthing to do with it, but I would advise that you shiould avoid special characters in object / variable names.
Perhaps I could get it to work as separate variables, but a workaround isn’t exactly what I’m looking for. What I meant was that those two functions work separately but I haven’t tried putting them both into the table at the same time, I’m guessing it will give the same result, the timeout. I’m just curious as to why it happened and I don’t want for it to happen again so I’m not touching it until someone internally investigates the issue.
Regarding the second comment, a valid suggestion but it is a universe-level object and ergo out of my domain as I’m just a reporting analyst. I also doubt it has anything to do with it because it has been successfully used countless times.
Did you find a resolution/workaround to your problem. I have users who are experiencing similar timeout problems, and using reports with complex report variables (as you seemed to be). I’d be very interested in your outcomes.
I messed around enough with the syntax of the formula, keeping the same logic but with a different build and it worked.
A couple of months later I ran into the same thing in slightly different context.
By now, I’ve just filed these under “one of those things…”. I shiver every time I validate a context variable.
