system
October 9, 2018, 12:48pm
#1
HI All
im new on BO Web Intelligence im not need to amend report to show revenue value between current quarter till date Vs previous quarter till date
currently in Time range filter i found filter for current quarter till date
but i didn’t found any filter for previous quarter till date
appreciate your assist how to do that
shado26 (BOB member since 2018-10-09)
system
October 10, 2018, 6:37am
#2
you can create conditions for previous and current quarters in universe level and can use as filter at report level
surya_sudheer (BOB member since 2006-11-01)
system
October 10, 2018, 7:25am
#3
can you help me with this
MarkP
October 10, 2018, 7:35am
#4
In terms of your quarters, are they calendar quarters or financial quarters that are different to calendar quarters?
system
October 10, 2018, 8:42am
#5
financial quarters
MarkP
October 10, 2018, 9:04am
#6
What quarter are we in now, when did it start and when does it end?
system
October 10, 2018, 9:08am
#7
Current Quarter is Q4
we start Q4 2018 in 30-9 will end on 29-12-2018
2017 start on 1-10-2017 ended 31-12-2017
i need to get revenue for QTD as today as this report will run automatically
MarkP
October 10, 2018, 10:11am
#8
OK. Do you have a calendar table in your database?
system
October 10, 2018, 10:40am
#9
NO i only option i have to select per day or week or quarter or year
MarkP
October 10, 2018, 10:57am
#10
Are you the universe designer or does someone else do that at your company?
system
October 10, 2018, 11:00am
#11
no someone else
MarkP
October 10, 2018, 2:30pm
#12
Ask them to build new objects for you called “Periods Ago” and “Day in Period”.
This should calculate the number of periods back from the current period that a given date is, as well as allowing you to compare the same number of days in each quarter.
You can then create a query filter of Periods Ago in list 0,1 which will bring back the current and previous period as well as adding Day in Period into your report so that you can limit the display to the max Day in Period where Periods Ago = 0
