Is it possible to have a Tick (✓ symbol in Webi report columns. I am trying to put a Tick (✓ symbol using Alerter. I tried copying the symbol in to the Alerter formula bar, but it isnt accepting. If there is a way, please let me know.
Thanks…
Work around - What are even going to do without this tantra
Save jpeg images of the sysmbols you are going to utilize in your alreters in a shared network folder.
Create new variable objects for your symbols
Define your alerter and in operands section click the three dots to browse for objects and variables and select the [tick mark] variable and vice-versa.
set the cell format to read as “Image URl”
PS: I tried with a cell content to display company logo in the report. Above steps are recommendation for conditional image display, havent tried it myself. Give it a try and let us know.
On your Windows start menu go to Accessories -> System Tools -> Character Map.
Scroll down and youll see the symbol.
Highlight it and click on Select and then Copy. It is then in your clipboard ready to be pasted wherever you need it.
By default that font won’t be there, I think you need add the information about the font in the defaultfont.xml file located inside the subfolder of Business Objects installation folder.
