Hello,
I want to set thousand separators in some Xcelsius objects .
For example 60000000 should be displayed 60 000 000.
But when I set the thousand separator option it shows 60000 000.
Any idea?
Thanks!
JFCab (BOB member since 2009-01-22)
Hello,
Any idea?
Thanks!
hi there
you can get this by using custom format in Excel spreadsheet
format cells and go to custom # ### ##0 use this format.
if you want currency format set $# ### ##0 like this.
Hope this helps
dandamudi (BOB member since 2008-07-03)
Hi ,
In a pie charts, format in Excel do not change it in the chart.
It’s working for Excel Spreadsheet object but not for other Xcelsius objects…
Any ideas ? :?
Thanks!
Ok I understood, In fact I have to set the format in Excel and then re allocate the object to the correct cellsÂ…
