TextDataProcessing not classifying Person
Text Data Processing is not classing Person as Person_Fam and Person_Pre rather displays as Person…
i.e. Mr.Jack displays as Person that Mr. as Person_Pre and Jack as Person_Fam.
Do I need to enable any option to view appropriately?
rajnia1 (BOB member since 2011-11-17)
Hi Rajni,
Text Data Processing will not work based on Cleansing packages. There are few default rule files available along with installation . You will get the output according to the rule files. If you need you can customize the file.
If you are using 4.1 you can use Text data Processing --Languages-resources folder for rule files.
Once you the Standard form from the text data processing , you have pass it to the cleansing packages( PERSON_FIRM) then only you will get the your required result.
Please refer the Data quality job in the Text data processing blue prints.
Thanks & Regards,
Ramana .
Ramana :india: (BOB member since 2009-04-30)
