I’m developing some dashboard and getting the data through QAAWS. When i review the data in the QAAWS tool every thing looks good, but when i want to load the data in a Pie Chart for example i only see numbers which divides the pie but i don’t see the legend at all. It only works if i wrote the text in the embedded Excel my self.
I’m really stuck with this and not able to progress. What could be the problem exactly?
The flow is:
SAP BW > BEx Query > Universe > QAAWS > Xcelsius 2008
Step One: In your Pie chart configuration, Binding Values is one step. Binding Labels is another step.
Step Two: Double Check the bindings on your QaaWS connector. If you know how to preview your qaaws data, then you know how many rows and columns are coming. Check to see if the range of the QaaWS connector is the right size.
