Text answer to question needs to be converted to number
We have a picklist of answers to a question and I need to assign each answer a score and then total the score. How do I assign the number to the answer?
Example:
Less than six months should have a score of 5.
Thank you!
What have you tried? You have not provided enough information for a comprehensive answer (e.g., valid answers).
A variable with a formula as follows might be a good start.
=If ([Answer] = “Less than 6 Months”) Then
5
ElseIf ([Answer] = “6 Month to a Year”) Then
10
Else
15
Noel
Hi Noel,
Thank you for replying! Can you tell I’m a newbie? :sunglasses:
I have a variable that worked until I referenced it in another variable to Sum numbers. Then I received a DataType error.
I have 4 fields that I will need to do this to (2 are yes/no so they should be easier). Then I need to sum the numbers from all 5 fields.
Should the variable that assigns the numbers be a Dimension or Measure?
Again, thank you for your help!
Mary
Newbie? We have all been newbies at one time or another. You have come to the right place!
Can you provide some sample data that fits your situation as I describe in this post?
Also, along with your test data mock up in Excel your expected result.
Noel
I figured it out! ElseIf statement works. Thank you!
