Hi all,
I have a strange result when using Load Triggers with a Teradata 13 target (via ODBC).
Normal loaders will batch up inserts by the ‘rows per commit’ value, issue a BT, then the compound INSERT then an ET.
I have had to use a load trigger to replace the INSERT operation as I wish to use a slightly modified insert statement (a string literal with the ''XB qualifier to load a varbyte column). This works fine, but very slowly.
When we look at the teradata logs we see:
BT
INSERT … blah
ET
ET (Error 3510 Too many END TRANSACTION statements. )
ET
BT
ET
(repeat)
Or to describe this, each insert is wrapped in BT/ET begin transaction end transaction, then there are several empty transactions.
I think even if the individual inserts were wrapped in a single BT/ET it would be much faster.
Does anyone know where all of these extra transactions are coming from?
From the manual, there is a bit of warning:
The software does not parse load triggers. Thus, when you specify a load trigger, the software does not parameterise SQL statements. As a result, load times might be higher when you use load triggers.
…but nothing is said about transaction control that I can see?
Any help greatly appreciated!
philmorris (BOB member since 2002-11-12)
