Hi all,
Has anyone ever had experience about pasting back (re-using) using a BIAR file a good security setup which was done earlier in another BOXI project. Importing the BIAR file and then do some tiny adjustments and then…ready!!
In the BIAR you have complete templates with Access Levels, usergroups, folder security…
In fact you would like to have a wizard which ask you questions and then makes the right security for you…but that does not exist… ![]()
TurningPointHolland
(BOB member since 2006-09-06)
