Tables within a Section
I have a report which is sectioned by Matter Number. Within each section, I have 4 vertical tables. Depending on the date range that I run, it is possible for the number of lines in each table to change. Is there a way to format the tables so that each time I run the report, no matter how many lines each table has, the spacing between the 4 tables remains the same?
ColleenW (BOB member since 2008-07-30)
This question was already created in another identical post and is also answered. see :
Marc Doucet :canada: (BOB member since 2007-07-11)
Closing topic, please use the original linked above, thanks.
