I am new to Business Objects and all my experience is in ETL tool.
Currently i have problem in identifying queries used in reports,
say for ex. i have 10 reports and i wanted to know the list of tables used to create those BO reports or the query used to build it.
I can see all the queries which are in query panel.But is there any other way to identify all the queries used in reports??
so that it will reduce my time instead of opening each and every report.
I have followed the steps,before that i need to update that am using version BO XI 3.1
I have went through the steps which has been said.
I have created folder which contains 10 reports and downloaded the DeskI Documents Inspector.rep in the same folder and i followed the procedure
when i reached point 4) which is “select working folder” when i selected, it took me to Microsoft Visual Basic and throwed an error saying
“Complie error: Can’t find project or Library”
It looks that some library is missing in the references.
Do it again and when you get to the point where you get the error message, go to menu Tools → References and check which library is not available. There should be written “MISSING: ” in the References - Project dialog. Then let us know which library it is.
I repeated the steps again, when i got the same error at particular point to check the references under tools menu, reference selection is disabled after i say OK to the error message.
Yes, because some of the libraries referenced in the project are from (belong to) BO XI r2. So if you want to run the same VBA code in BO XI 3, then some libraries need to be changed.
