tableowner.tablename help
How can I get the tables in designer to not display the owner?
All of my tables show tableowner.tablename and I would like to see just the tablename.
Janie
Hi Janie,
  1. Select all the tables by clicking from Edit menu and right click on the table name (any one)
  2. Select Rename Table Name
  3. You will see the owner group and you need to delete the owner group and click on OK.
    It will remove your owner group name for all the tables.
Hope it helps.
Ravi.
From: “Pflaum, Janie” janie.pflaum@DOT.STATE.WI.US How can I get the tables in designer to not display the owner?
Janie
Web archives (24 hrs. a day now!): listserv.aol.com/archives/busob-l.html
______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
But isn’t there a way you can set this as default to not show the tableowner?
Hi Janie,
Janie,
In the BusinessObjects files, the parameters in the PRM file corresponding to your RDBMS indicate how the qualification of tables can be managed.
In the General Section of the file there are two parameters for this :
OWNER=N
QUALIFIER=N
Try this out.
Durgesh
Janie
Thanks to all who have responded. I truly appreciate your quick responses.
Janie
Hi Janie,
Hope it helps.
Ravi.
Still didn’t work.
We are using db2, there are 5 prm files in our bo\data access\db2 folder. We’ve changed the suggested settings to no and when we import tables it still has the owner name.
Any other thoughts?
Janie,
OWNER=N
QUALIFIER=N
Try this out.
Janie
