Hello Experts,
We have now upgraded from DI 11.7 to DS 12.2.3 on production as well and many jobs failed giving the access violation error and creating dump files on the server. We also tried to switch to in-memory cache… In some cases it was succees but taking more time to load the data.
(12.2) 10-27-12 02:15:52 (E) (3140:9240) FIL-080105: |Data flow INIT_EKKN_DF|Reader INIT_EKKN_R3DF
A row delimiter was seen for row number <1173419> while processing column number <19> in file <//wprosg/P01/ZDX3098_EKKN.dat>.
The row delimiter should be seen after <20> columns. Please check the file for bad data, or redefine the input schema for the
file by editing the file format in the UI.
A row delimiter was seen for row number <1173504> while processing column number <19> in file <//wprosg/P01/ZDX3098_EKKN.dat>.
(12.2) 10-27-12 03:53:50 (W) (000:000) ABT-200201: Job with pid <8516> is killed.
(12.2) 10-27-12 03:53:50 (E) (8516:2280) SYS-170101: |Session IASCF_JOB|Work flow FACT_load_WF|Work flow EKET_Correction_WF|Data flow EKET_Correction_DF
System Exception <ACCESS_VIOLATION> occurred. Process dump is written to <I:\Program Files\Business Objects\Data Services XI
12.2\log\BODI_MINI20121027020259_3396.DMP> and <I:\Program Files\Business Objects\Data Services XI
12.2\log\BODI_FULL20121027020259_3396.DMP>
Process dump is written to <I:\Program Files\Business Objects\Data Services XI 12.2\log\BODI_MINI20121027020259_3396.DMP> and
<I:\Program Files\Business Objects\Data Services XI 12.2\log\BODI_FULL20121027020259_3396.DMP>
Call stack:
001B:00E2894F, vcharUserInterfaceRegular::allocVchar()+0079 byte(s), x:\src\eval\vchar.cpp, line 0511
001B:00E1C95A, XRow_data::get_addrAndAlloc()+0234 byte(s), x:\src\eval\row.cpp, line 2196+0137 byte(s)
001B:00E1D53B, XRow_data::get_addrAndAlloc()+0043 byte(s), x:\src\eval\row.cpp, line 2188
001B:00A693A7, Flat_file::getColumn()+2231 byte(s), x:\src\filespec\flat_file.cpp, line 3000
001B:00F4BEFD, RdrFile::getnext()+0621 byte(s), x:\src\reader\rdrfile.cpp, line 0963
001B:00F3414B, RdrAdapter::execute()+0027 byte(s), x:\src\reader\rdradapter.cpp, line 0787
001B:00E527F1, XTran_desc::execute()+0273 byte(s), x:\src\core\xtran.cpp, line 0588
001B:00D2C223, Rww_thread::main()+0083 byte(s), x:\src\rww\rww.cpp, line 0425
001B:01B4C20B, RWThreadFunctionImp::run()+0139 byte(s)
001B:01B3C9D2, RWRunnableImp::exec()+0226 byte(s)
001B:01B4C4DC, RWThreadImp::exec()+0076 byte(s)
001B:01B4D819, RWThreadImp::setTimeSliceQuantum()+0249 byte(s)
001B:77E6482F, GetModuleHandleA()+0223 byte(s)
Registers:
EAX=05FB842C EBX=04728F80 ECX=0000002D EDX=05FB8420 ESI=00000001
EDI=05FB62E0 EBP=00000022 ESP=0930F99C EIP=00E2894F FLG=00010206
CS=001B DS=0023 SS=0023 ES=0023 FS=003B GS=0000
Exception code: C0000005 ACCESS_VIOLATION
Fault address: 00E2894F 01:006E294F I:\Program Files\Business Objects\Data Services XI 12.2\bin\acta.dll
Please collect the following and send to Customer Support:
1. Log files(error, monitor_, trace_*) associated with this failed job.
2. Exported Atl file of this failed job.
3. DDL statements of tables referenced in this failed job.
4. Data to populate the tables referenced in the failed job. If not possible, get the last few rows (or sample of them) when
Please suggest how to resolve access violation error and long running of flows. need it urgently as it is on production.
Thanks & Regards
Kavita3110
kavita3110 (BOB member since 2012-08-30)
