Oracle.
Do I need to create an object in the universe?
I did that with sysdate, it did not parse but worked in the report.
Can I not avoid the object creation and use some feature in the reporter?
There is a current date function in Reporter and you can build a variable based on this but that will not do you any good if you are trying to condition on the actual query, thus limiting the results returned based on a sysdate.
