i need to create sysdate in universes level
class :object:sysdate
then i link with one table
it working fine
but when i cheked with another tables…
its not working…
can u tell me solution…
nsai (BOB member since 2007-03-27)
it working fine
its not working…
Please tell us what “its not working” means … error message, unexpected behavior?
Dwayne Hoffpauir (BOB member since 2002-09-19)
yes it showing error Here
cartesion product
can u please tell me solution.
cheers
Nsai
Check the joins. You might not be linking them properly.
I had the same problem too when I cross checked my joins I was linking a charecter feild to numeric feild.
Cheers…Ramala
ramala (BOB member since 2007-07-13)
Hi ,
just i have 5 tables okk
i dint join any table
just i need sysdate in universe level
i create object and i link point to one table
when i run reports its showing fine sysdate
but when i drag object from another table
it showing error cartesion product.
cheers
Nsai
Are you creating a join or not between the two table you are pulling data from?
Without linking the tables properly I dont think you will get appropriate data.
I would imagine that is becuase you have not defined any joins between your tables…?
Mak 1 (BOB member since 2005-01-06)
sysdate objects should not be related to any table, therefore they will avoid any cartesian warning when used with different tables. The object will not parse, but will function on a report. I believe this is covered in the FAQ.
You try something like this if you would like to use with database objects without an error
select table_name.date_feild
from table_name where table_name=sysdate()
this should work if joined properly.
