SYSDATE as key
Hi, trying to get the following syntax right in DI but struggling, any help appreciated, thanks.
(on ORACLE 10)
would like to see SYSDATE()-1 as a key e.g. 20091115 (decimal field)
any ideas, thanks.
mjs8274 :uk: (BOB member since 2006-04-26)
to_char(sysdate(), 'YYYYMMDD')
You will get a warning message that you are assigning a char to a decimal but that’s fine, values like 20091115 can be converted implicitly. If you want to gt rid of the warning message put it inside a cast function.
cast(to_char(sysdate(), 'YYYYMMDD'), 'decimal(8,0)')
nice, thank you!
