Syntax error DMB0007 using Where
Situation
In my report I retrieve data for months 1 to 4. The sum of this is shown in a column but I also need a column with the value for the last month in the range (in this case 4). So in 1st column months 1 till 4 and in 2nd column only month 4.
Problem
Because I’ve got data for 4 months I thought to use the Where, in my case like this:
=<Realisation(Real with Um1a0006)> Where (<MonthNum>=<ParMonth>)
Explanation: <Realisation(Real with Um1a0006)> is the measure, is a dimension with the month from the query, contains the user parameter with the month.
But maybe you guessed :lol: , I get the message “Syntax Error DMB0007”. I checked that both variables and are numeric. :yesnod: When I use
=<Realisation(Real with Um1a0006)> Where (<MonthNum>=4)
or
=<Realisation(Real with Um1a0006)> Where (<ParMonth>=4)
there is no problemo :roll_eyes: .
Any ideas for a solution or a workaround (a troublesome workaround would be to create a separate query for last months data).
My BO version is 6.5.1 full client with SQL Server database.
HenkK
HenkK :netherlands: (BOB member since 2004-03-02)
Just say If = Then …well try it anyway.
Nick,
I tried this:
=If (<ParMonth> = <MonthNum>) Then <Realisation(Real with Um1a0006)>
and I got a computation error … :frowning:
To avoid the possible numeric problems/conversions I created to objects with the derived monthname (character), but with the same result: a syntax error …
I don’t know anymore … :roll_eyes: :roll_eyes:
HenkK
Avoid using the IF…THEN…ELSE solution if possible as you would have to have all referenced dimensions in your block/table. Instead, look at this Reporter FAQ entry.
Andreas,
It’s a good workaround, although at first it didn’t work for me (at first) (I got a “Variables are not compatible”). That is another way :mrgreen: helps, not always direct but stimulating further digging and trial and error.
The reason it didn’t work was that the 2 objects I use are from different queries :wah: . Now they are in one query and voila, it works! :yesnod:
HenkK
