Hi there
Is it possible to create a universe on MS SQL using synonym tables? I am unable to see them in the schema.
I have access and can view them from MSSQL Studio, but not through IDT.
I see there is a parameter that needs to be set for use with Oracle but not sure if this is the same for SQL?
We are using BO 4.1 sp5 and SQL 2008 (I know -it’s ancient, I can’t change it though??)
SarahG (BOB member since 2005-08-22)
