Switching off/on unique constraints defined on rapid marts
I need a suggestion on rapid marts jobs.
There are various facts and dimension tables as part of all modules that have constraints defined on multiple fields based on the requirements.
Lets say we removed all constraints from certain tables in order to run specific job which was failing due to constraint error earlier and let all records run at FIRST load.
Before switching the load as DELTA,
1)how important is putting all the constraints back to the original
2)how will the reports be affected
its_ranjan (BOB member since 2011-02-16)
