SWF not reflecting the changes.
i have a XLF file which was running properly till yestaerday.But when i do do any change to the XLF file and run the SWF on my local the changes are not reflected.It appears that it points to the same SWF which was there before the change.
I cleared all the cookies and temp files on the explorer but still the problem exists.
Also the original file was made on Microsoft Office 2003 and now I have installed 2007.Can this be the issue?
vineeta04 (BOB member since 2009-01-05)
Well Yes, that may be the issue. :wink:
Can you please share which type of changes you did so it will be better to understand the situation?
vijesh.chandra :india: (BOB member since 2009-05-29)
You have to install Xcelsius on top of Excel. So if you upgraded Excel versions, then you should uninstall Xcelsius, then reinstall.
Cairmor :us: (BOB member since 2008-06-05)
Thanks to everyone.
Microsoft Office 2007 was the problem.I reinstalled 2003 and able to make the changes.
I have an SWF exported from Xcelsius that was modeled from the excel output of a crystal report. The swf has been linked to a new copy of the crystal report and imported back into Crystal Enterprise.
When I run the report with the swf inserted and connected by swf data connection to formula fields from the Crystal report, the swf does not refresh, it still has the orig output when it was first exported.
What am I missing?
BOB Guy (BOB member since 2009-10-11)
