Hi - In the newer versions of CR when Formatting Subreports there is an option to Suppress Blank Subreport - I dont see that in 8.5. Any idea on how I can do that?
raiderfan (BOB member since 2005-09-02)
In Crystal Reports 8.5, the Subreport tab in the Format Editor does NOT have a checkbox for Suppress Blank Subreport.
This means there is no easy way to do the same in the 8.5 version.
Try working along these lines
Add one of the special fields like GroupNumber or RecordNumber into the report. It does NOT need to be seen, so suppress it.
Then on all the report objects column labels, border lines, titles, etc do a conditional suppression if GroupNumber or RecordNumber is less than 1. That should effectively blank out everything in the report.
Chamsin (BOB member since 2008-06-05)
